FIXED Insinkerator Trips GFI
Fred Schwartz
My In-Sink-Erator constantly trips my GFI outlet. The 'blade' is not stuck it turns freely and runs for a second before tripping the GFI.
Fred Schwartz
I know In-Sink-Erator is not GE but the name "In-Sink-Erator" was not available on the provided list; nor was Emerson.
Hi Fred,
Try it on a normal NON-GFI outlet.
Fred Schwartz
Good morning Jake,
I plugged it into a normal outlet and it did work fine. I assume this means that the GFI outlet is bad. Should I replace it with a new GFI outlet or a normal outlet?
Fred
Fred Schwartz
It also looks as though the garbage disposal has a “trip switch” on the bottom. Does that do the same thing as the GF I outlet?
Ok Fred,
Appliance Manufacturers recommend always plugging appliances into NORMAL outlets.:)
The trip switch on bottom is for internally shorts or overheats.
Glad to help Fred.(y)
