Installation Question - Spacers?
Festivus
Columbus, Ohio
Less than 1 year
Just installed a new under cabinet microwave. My cabinets have a lip around the edges under them. Maybe 1/2 inch or so. I didn't have spacers to use between the top of the microwave and the bottom of the cabinet so I just screwed it in without them. Seems solid as heck. The old one was installed the same way, without spacers. Never caused an issue.
Is this going to harm my microwave? Can't seem to find any information online re why spacers might be necessary here.
On OTR ( over the range ) microwave?
Not likely.
So the top of the mocrowave is not flat against the bottom of the cabinet....right?
Festivus
Columbus, Ohio
That's correct, Jeff. It's on over the range unit. And yes, the top of the microwave isn't flat against the floor of the cabinet. But the front and the sides of the unit are flat against the lip that runs around the boundary of the cabinet bottom.
Shouldn't hurt anything.
Sometimes the non-flat bottom cabinet can effect the air flow for the exhaust fan, as long as that is not an issue I wouldn't worry about anything.
