Intermittent Drain Problem Kenmore MOD# 465.13349600 (Duel Drawer Dishwasher)
spta97
New York
Hi all,
I have a Kenmore MOD# 465.13349600 (Duel Drawer Dishwasher). A few weeks ago, it would not drain (top drawer).
I took out the pump and noticed the blade was caught on a piece of a dish so removed it - figured the problem was fixed as it happened once before.
Ran a fill then drain and it drained fine. Then ran a cycle and it would not drain.
I figured it might be a plug in the hose so I sucked them out with a shop vac.
Since then, it has been working fine until last night where it would not drain again.
I took out the pump again and it looks fine (no obstructions). It reads 27.3 ohms across the terminals.
I saw this thread but not sure if that is my problem. Mine does buzz when it fails to drain.
If it is, I wonder if it is time for a new diswasher it is ~15 years old.
Any further tests I can do to isolate the problem?
When its buzzing and not draining it sounds like the drain pump is possibly starting to fail intermittently now. So you'd either need to replace it, or buy a new dishwasher.
spta97
New York
Thank Jake. I wonder if the motor got damaged by the piece of the dish that was stuck?
Is there any way to confirm the motor is failing via multi-meter tests?
That's exactly what I was thinking!
Yes, when its buzzing remove the electrical connector from it and put your meter probes in each of the 2 electrical connectors and see if your meter reads 120 volts. If you get 120 volts, then its definitely the drain pump.
spta97
New York
Thanks Jake!
From your post it seems I would be testing for power to the pump. Assuming it is getting power, that would indicate the pump is faulty.
The more I think about it that makes sense. Last time it tried to run and didn’t drain, the pump was hot indicating the propellor wasn’t spinning and cooling it with water.
Yes, its getting proper power, so I'd just replace it and that should fix it.:)
