Intermittent Power Interuption
kenquagliana
Maryland
R 5A51
Sharp
Hi Folks. This unit runs and heats normally for a few seconds to a few minutes then shuts down. It acts as if losing power; the display flashes slowly and reads all "8's". I can reset it. Then it will repeat.
I've checked all the door switches; Fuse and Hi Temp sensor (all good). Primary side of the HV Transformer reads a low ohm value and is good (I think).
I think the HV Can Cap is the issue. With the two terminals connected to my meter, the ohm values are dropping instead of rising (as I understand it should); The capacitor is a .88 uF / 2000V (not sure if it has the 10 ohm resistor - no indication on the capacitor). The Diode reads all zeros??? (not sure if its good - If I can replace the capacitor, I was going to replace it just to be sure). So far - no luck finding this capacitor.
Questions: Can I substitute an HV capacitor with a value of +/- 3% (.85 -.91)?. With or without the resistor??
Thanks in advance.
Ken Q
Baltimore
Main power cord, outlet plug, fuse holder, fuse, cabinet thermostat, loose wire, main pcboard.
Ohming is a great tool, but often will not help with loose of power or intermittent issues.
I doubt it, this is for cooking only.
LINK> Capacitor Testing | Appliance Aid
Unless you have a very high end meter, you can't check the diode.
kenquagliana
Maryland
Hi Jeff, Thanks for your prompt reply. Ok. I rechecked the can cap as described in your link (using my old analog meter) and it checks out good. When this machine runs for a few seconds it IS heating the cup of water normally.
All the other AC stuff checks out. I'm starting to think it's in the main PC board. When I first plug it in, it takes a while for the display to stabilize. Like it's charging up. Maybe it's a bad cap on the board?? But again, it acts like it's tripping a resettable breaker, or the relay isn't holding.
So, since PC board troubleshooting and repair is way out of my league, I'll try to find one before admitting defeat!!
Thanks in advance for any other ideas or suggestions. This is a well built unit. Hate to throw it away.
Ken
Baltimore
