JDRP436WP03 Jenn-Air Range F2E3 Error
JFerguson
JDRP436WP03
Jenn-Air
Recently I replaced the board on this gas range as it would not start up properly. Now the touch screen does not accurately respond, some parts of the screen respond properly and the bottom buttons do not respond at all. I can access some limited functionality but if I mess about I eventually get the F2E3 error. Not sure if I need to replace more parts or if I just simply did not install properly. Any advice would be of great help.
I question the wisdom of putting touch screen interfaces into gas ranges.
F2E3=Keypad Hardware Failure
1. Check for proper voltage input at the user interface board connections J900-11 to J900-1 by completing the following steps.
2. Unplug range or disconnect power.
3. Connect voltage measurement equipment.
4. Plug in range or reconnect power and confirm voltage reading is +14 VDC. If it is, unplug range or disconnect power and go to Step 7. If it is not, go to Step 5.
5. Unplug range or disconnect power.
6. Check that the User Interface connection is firmly connected.
7. Replace all parts and panels before operating.
8. Plug in range or reconnect power.
9. Observe for longer than 1 minute.
10. If error remains, go to Step 11.
11. Unplug range or disconnect power.
12. Replace oven user interface communication harness.
13. Replace all parts and panels before operating.
14. Plug in range or reconnect power.
15. Observe for longer than 1 minute.
16. If error remains, go to Step 17.
17. Unplug range or disconnect power.
18. Replace oven user interface.
19. Replace all parts and panels before operating.
20. Program model number. See the “Programming Model Number After User Interface Replacement” section.
21. Plug in range or reconnect power. Wait for 1 minute.
22. Verify operation is normal. Re-enter the Diagnostics Mode and complete checks.
Here's the keypad user interface board for your model:
User Interface Board
Ok, sounds good.
