JDS9865BDP22 Jenn-Air Range buttons quit working
tinman9988
Seattle
JDS9865BDP22
Jenn-Air
After a power outage several years ago, the buttons on my JennAir JDS9865BDP22 range quit working. Would it be able to tell which part needs to be replaced? The display (clock) is still working but since the buttons don't work, the time cannot be adjusted. Is it the control panel (with the buttons) that needs to be replaced or the oven control board?
Corrected model number
We need your complete model number first. Read the model number from your model number tag on the range.
Click here: Appliance Parts
Here's the results I get:
JDS9860CDS00
JDS9860CDS01
JDS9860CDS02
tinman9988
Seattle
Thanks for the link to determine the model number. Turns out, I was wrong! The actual model number is JDS9865BDP22.
tinman9988
Seattle
Now that I have determined the actual model number, would the control panel touchpad part need to be ordered?
Ok, thanks!
If the clock is working but the control panel buttons are not responding then you'd need to replace the control panel touchpad.
WP5760M373-60 Panl-Cntrl
Glad to help, let us know how it goes.
tinman9988
Seattle
The new control panel showed up when I am running into a problem when removing the existing panel. Specifically, I can't access the two screws on both ends of the existing panel because they are blocked by the kitchen counter. Any ideas?
tinman9988
Seattle
Is it possible or is it a good idea to attempt to pull the range out a bit so that I can get to the screws on both ends of the panel?
tinman9988
Seattle
I think I don't have to pull it out. I just need to raise it up. I plan to get a crowbar and some scrap wood that I can place under the oven frame.
