FIXED Jenn Air JDB8700AWS3 starting and cycling down - blue light blinks 1x - starts again - repeat
Chris Guess
Texas
JDB8700AWS3
Jenn-Air
My Jenn Air Dishwasher - It starts like normal for a minute...then the water swooshing stops, the blue light/control panel blink once...and it starts the process over again. It will do this endlessly until stopped and I have to manually hit "Cancel" for it to drain (which it oddly doesn't stop draining until the door is opened).
After doing a little searching...I thought it was the High Limit Sensor because it wasn't providing any reading for continuity. We ran the diagnostic and got the error codes 6,4 and 6,6. I decided to replace the High Limit Sensor and the Water Inlet Valve...and no dice.
I'm starting to think it's the Control Panel or Control Board...? Thoughts? I'm leaning towards the control board since the touch panel works fine. Any advice would be greatly appreciated. I don't want to keep replacing parts for not.
Thank you
Chris
Hi Chris,
Anytime you replace a part on these dishwashers you always have to run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that now, and report back.:)
If that does not reset your dishwasher back to normal, OR it does not go through the 23 minutes diagnostics cycle and hangs up, read below:
There has been a problem with the door vent assembly that can cause this problem, our other tech bigbuck brought it to our attention. It has also been making the diagnostic mode go off kilter/hangs up, if yours is doing that--->then disconnect all the wire connectors to your door vent and see if it runs through a complete cycle.
Start reading what bigbuck said at post#18 here: FIXED: KUDE60HXSS5 KitchenAid Dishwasher Fills but then Shuts off
Your model uses the exact same door vent. If it runs through a complete cycle, then order and replace the door vent assembly.
Here it is:
WPW10469574 Vent
Chris Guess
Texas
Sir...I might owe you a drink! The diagnostic ran a full cycle (I had no idea it was supposed to last more than a couple minutes)! I have ordered the part and it will hopefully be here Sunday. Thank you
Excellent Chris, yes keep us posted.:)
Chris Guess
Texas
Jake Sir! You are awesome! That vent appears to be the culprit. I replaced it yesterday and ran the 1 hour wash cycle as a test...appears to have run fine! (knowing my luck, I'll get the dishwasher remounted and put all the covers back on and something else will break - but we'll cross that bridge when we get to it...)
Thank you very much for taking the time to answer my post and point me in the right direction! I owe you one!
Excellent Chris, glad to hear the new door vent fixed it. (y)
