FIXED Jenn Air JMV8208BAS blows line fuse when vent opens/closes
MIROHO
Connecticut
JMV8208BAS
Jenn-Air
While heating cup of water microwave powered off and vent door remained open. Line fuse blown, replaced fuse, unit restarted, clock set, pressed button to close vent door - fuse blew. Door still open.
Door motor is controlled by two switches. Is it possible that one or both of these switches is the cause? If I remove them and the motor, how do I test the motor?
Motor-Driv by Whirlpool Part Number DE31-10154C
MIROHO
Connecticut
Update, microwave heats up food and the vent door opens/closes. But start the vent fan while microwave is running the fuse blows. Any ideas why?
I will see if Rick can help you.
Sounds like a door switch adjustment but I don't have the wiring diagram for that model. Can you post a copy of your tech sheet here?
MIROHO
Connecticut
Hi, I made six scanned images as the page is larger than 8.5" x 11". I've only sent Page 03 b/c I believe that is what your looking for. Let me know if you need additional info. Model=JMV8208BAS S/N=16320718NP MANUF DATE= 08/2008
That's very hard to read, I'll ask bigbuck if he has it.
I'm not sure what "vent door" you're referring to but if it's opening and closing I guess it's good. Will the vent fan motor run normally if the microwave is not cooking? With the vent motor on and running start the microwave. Does the fuse open?
MIROHO
Connecticut
Hi Rick, The unit is a combo MW and Range Hood with a vent fan. It does not vent outside, it vents into the kitchen via a vent, at the top, across the full width. A door covers the vent louvers and is opened via a motor, the Service Manual refers to the motor that pushes the door open as "Louvre Motor". A switch on the control board or a thermo-switch can signal the motor to open the louver door. I can open and close the vent and run the fan through all 5 speeds, (using the control board switches) providing I have NOT turned on the microwave. I've run the microwave for 2 minutes, no issues there. Then, while the MW was running I started the fan and the fuse blew (opens). Hope this helps.
Many thanks, Michael
... the motor that pushes the door open as "Louvre Motor".
Gotcha...that's what I needed. OK I'll assume we're talking about the 20 amp ceramic fuse that "blows" and that you're replacing it with the same. Measure the resistance of the vent motor. If it's 30Ω (± 2Ω), replace the main board:
Control Board WPW10127101
MIROHO
Connecticut
Hi Rick, please excuse my ignorance. When testing the motor's resistance am I correct to assume the following:
- Disconnect power cord
- install new fuse (20A ceramic - Bussmann ABC Series) . Which is what I've been using.
- When testing do I disconnect the motor or leave it connected and squeeze the probes in?
- Or should I disconnect the motor and test the power input wires?
What has me confused is that if I am testing the motor's resistance how does that prove the board is good or bad?
Many thanks Michael
MIROHO
Connecticut
UPDATE: just realized the MV did not heat up the cup of water. Tested the three door switches and they are OK. So, is it the magnetron or, something else, or two things like the diode?
MIROHO
Connecticut
UPDATE 2: I removed capacitor test continuity and meter gave audible beep. Does that meed the Cap is no good?
How to test high side components:
Less expensive meters may not have the ability to test the capacitor or diode. Use a 9 Volt battery:
Thanks Rick and bigbuck for helping MIROHO on this microwave.:)
MIROHO
Connecticut
With DMM set to diode testing - Diode - .OL I assume it's OK
With the DMM set at 200 (audible) I get the following readings:
Magnetron 0.1 Audible sound - I assume it's OK
Capacitor 0.1 (down from about 3), Continuity tested across terminals - Yes (audible sounds) I assume it's OK
HV Trans Primary = 0.1, Filament = 01, audible sounds in both cases. I assume it's OK.
I could not figure out how to test and get a reading on the secondary windings.
The "Bottom Thermostat" did not give a positive reading when tested for continuity, the adjacent "Hood Thermostat" did test positive (audible sound).
Per the Component Testing Procedure:
Bottom Thermal Cut-Out (Thermostat)
Disconnect all wires from TCO.
Measure resistance across terminals. ........
Non–resetable.
Open: ....... 248° F (120° C).
Is it possible that this bottom thermostat is the cause?
Many thanks for putting up with my ignorance. And, I have to say that I know more each day, which is a rewarding experience.
On the diode function the diode should show continuity (closed) then reverse the test leads and the diode should show no continuity (open).
Set your meter on Rx10K ohms (10,000Ω). Measure across the two terminals. Your meter should show several thousand ohms and fall back to ∞ (open or 1). Set your meter to the lowest ohms setting Rx1 and measure from each terminal to the capacitors metal case. Your meter should show open or ∞ or 1.
Set your meter on the lowest ohms scale Rx1. Remove the secondary wire from the HV capacitor. Measure from the secondary wire to the metal body of the transformer or one of it's mounting screws. Your meter should between 60Ω and 120Ω
The "Bottom Thermostat" did not give a positive reading when tested for continuity, the adjacent "Hood Thermostat" did test positive...... Is it possible that this bottom thermostat is the cause?
No, One thermostat is a normally open thermostat. It closes at a set temperature.
Test the switches by opening and closing the door. Don't just push the switch button.
It's starting to get a little confusing with this machine so where exactly are we ?? Are we troubleshooting a non-working microwave or a vent motor that blows a fuse or both. If you want to know if one of the high side components is bad you need to know if there's 120 VAC across the two primary terminals on the transformer. If there's 120 VAC going to the transformer one of the high side components failed. If there is less than or 0 VAC going to the transformer the problem is elsewhere.
MIROHO
Connecticut
Hi, before I start testing I'd like to point out that my DMM does not have the Rx settings you refer to. It have 2M, 200K, 20K, 2K, 200 (AUDIBLE). So my lowest setting is 200, correct? See attached image of DMM Commercial Electric MS8301A DMM.PNG. So how does my setting relate to your settings? (Black probe in COM, Red probe connected to the Red Opening to the right.
I removed the three door switches from the unit and tested them. I see you recommend testing while they are in the unit. Makes sense as maybe the door latch is worn and not applying sufficient pressure.
Last time I blew (opened) the 20A main fuse I had the microwave running, with cup of water inside the unit, and water never got hot. While the MV was running I turned on the vent fan and that is when the 20A main fuse blew (opened).
Sorry for making this so confusing and appreciate your patience.
