Jenn-Air JMW9527CAB Oven No Longer Heating
stugotz
California
JMW9527CAB
Jenn-Air
Hi guys,
I have a Jenn-Air wall oven that's stopped heating. I lost the broiler a couple years ago, and lost the bake about a week ago. The keypad works, I can set my temp and begin baking but the oven stays at 100 degrees, and occasionally it'll click like it's going to get started but it never does. I tested both the broil and bake elements, the broil ohm'd at 16 and the bake ohm'd at 22. I also have continuity on the high limit thermostat, but other than that, I don't know where to look. Any and all help would be greatly appreciated.
Both elements connect directly to the relay board. If the elements and the high limit thermostat test as Ok, the relay board is very likely responsible. Unfortunately the relay board # 74006612 is discontinued and NLA. It would need to be sent away to be repaired if needed.
LINK > JennAir 74006612 Relay Board Repair Service
stugotz
California
Thank you for your reply. I'll send the relay board off for repair and hopefully that fixes the issue. Thanks again
