Jenn-Air Microwave: Accidentally ran it empty
jeffmcpherson
imported post
I meant to use the "timer feature" but I ran our Jenn-Air Microwave for 20 minutes without anything in it. It doesn't work any more. Is there an internal breaker/relay? or did I likely fry the magnatron . . . or whatever it's called
imported post
Doesn't work at all or just doesn't heat?
Is there an internal breaker/relay? or did I likely fry the magnatron...
If it doesn't work at all (no lights, nothing), there is a fuse inside which could have blown. If it just isn't heating, the magnetron tube or some other part of the heating circuit could have been damaged.
It would have to be checked out to determine the exact cause of failure in such a case.
JFYI
Appliance411.com
=D~~~~~~
jeffmcpherson
imported post
It runs but it doesn't heat. Sounds like the heating circuit needs to be checked out. Thanks.
