- JMV8208BAS
- Jenn-Air
- 6-10 years
I have a JENN AIR JMV8208BAS microwave that keeps blowing one or both of the two internal fuses on the noise filter board. I have replaced the HV capacitor, diode and magnetron. I tested the HV transformer and thought it was ok but now an appliance repair service tells me that the HV transformer is bad. I'm not sure that I believe their conclusion because when I unplugged the HV transformer, magnetron, capacitor and diode and then started the microwave the second fuse on the noise filter board blew.
I've also tested the door switches with an ohmmeter to verify that they're working. A repair technician said that the door switches could blow the internal fuse but I don't understand how that's possible if they don't connect to ground. I have also run various test with items disconnected to try and isolate the short. I disconnected the blower motor, mixer motor turntable motor and the fuse still blew.
I'm thinking the the short has to be on the main control board.
