Jenn Air microwave doesn't heat---turntable doesn't turn
masterclean5
corona ca
JMC8127DDB
Jenn-Air
Hi Everybody,
Thanks in advance for your help. I greatly appreciate it. My Jenn aire Model# jmc8127ddb does not activate(heat food) or turn the turntable when I press the cook button. The light does go on and the timer does count down. What might this be?
From other research here, I found that it might be a bad door latch.(Where the 2 prongs enter the main unit from the door, only one side has a part that will be depressed when the door is closed; the other side doesn't. I'm thinking the side "where it doesn't" may have a broken part.)
Thank you again, Kent
masterclean5
corona ca
microwave 2.jpgmicrowave 3.jpgSorry these pics are sideways but as you can see, the first pic shows something for the door latch to depress(make contact with...), the second pic shows an empty space, nothing to depress. Hope this helps
Correct and normal....one pushes in, one goes in and drops in place.
Definetly check door switches, door switch mechanism, door key ( the hooked part ).
Micro-Switch-3B73362F-01053786.jpg Micro switch, normally open Manufacturer Number 3B73362F
[video=youtube;BlAcB5rJugI]http://www.youtube.com/watch?feature=player_embedded&v=BlAcB5rJugI[/video]
