Jenn Air Microwave Fuse
maxdave
Georgia
The Microwave was built in June 1991 and is a built in unit attached to an oven. Both unit's slide out from the cabinet. Purchased with a house recently and the fuse was blown and replace prior to moving in and has apparently blown again. How do I get to it to replace it?
maxdave
Georgia
Tried to locate a model number on it but could not locate same. It is attached to a Jenn Air convection oven. I pulled them both out of the cabinet and did not locate an external fuse.
