- JMV9186WP0
Hello, I have a JENN-AIR microwave model: JMV9186WP0 and the appliance seems to work fine for 1-minute increments. I have experimented with trying to boil water with a voltage monitor plugged in. Line voltage is 120VAC and under normal operation the voltage drops to 117-118 volts. If you set the timer for 1 minute seems to work fine, but set it for 2 minutes the Magnetron cuts out and the voltage returns to 120 volts. Could this be the Thermal Fuse?
