Jenn Air Microwave vent door motor wont stop
gs9632
USA
jmv8166bas
Jenn-Air
After I used the combination cooking feature (micro/convection oven) the vent door started to open an close endlessly. Only stops when microwave is on. The vent door will not respond to the fan being on (it doesn't open at all w/ the fan on, but stays in whatever position it was in when the fan button was pushed). I've unplugged to reset w/ no success. Any ideas?
Responses don't usually come within 10 minutes.:)
Within 24 hours, yes.
My bad, I thought you posted that today.
Ok, Refund on its way.
