Jenn air no convection
swebeaux
louisiana
Jenn air mod# JMC9158BAB microwave oven with convection, the microwave works fine but no convection. Able to select convection the convection fan turns and the control board displays convection. The heating element and safety thermostat have continuity,but no voltage to the element. I'm betting its the control board, there was no schematic or tech sheet so I don't know what other components may be in the circuit
TechnicianBrian
Portland, OR
You are probably correct about the control
board if the rest tests OK. Using a meter, check for voltage from the red wire connected to the element to the chassis. If all is well, you should read line voltage. If not, then there is a problem with the black wire as it should always have line voltage on it. The red wire plugs into a relay on the control board which when closed provides the neutral path and a complete circuit. You can check the back of the board for a bad solder joint, but you may need to replace the board. Check it out and let us know.
