pfl
- JDS9860AAP
- Jenn-Air
- More than 10 years
I am having a problem with my jenn air jds9860aap (buzzing and low voltage to the bake/broil elements)
The buzzing DLB relay wp74003482 failed a couple years ago and I replaced it and it worked for a year before it failed again. It worked for another year before failing. This time though it only lasted 24 hours. I am getting 45 volts on the control voltage side. Does this indicate that the board is sending the wrong voltage causing the (24v?) relay to fail prematurely? So now I would need to replace both the relay and control board? I checked the resistance on the broil element at 15 ohms and the bake element at 25 ohms. Is there anything else that could be causing these problems? I want to make sure the board is the problem before I replace it since it is pricey.
model # is JDS9860AAP
Serial # 20421817ER
If I do need to replace the board, is this the correct one for my serial number?
Serial # 20421817ER
