Jenn-Air Range SVE47600B F7 error code
lsstegall
Greenville, SC
SVE47600B
Jenn-Air
The broiler stays on regardless of whether I've turned it on or not. I get an F-2 code. Eventually I get an F-7 code. What parts do I need? The stove is 21 years old.
Is it glowing red hot or just staying warm continuously?
If it's stays glowing red hot, the only thing that could cause that is a defect in the electronic control. The power relay for the broil element circuit is shorted. In that case the electronic control is likely defective and needs to be replaced.
LINK > Electronic Control WP71001799
The F2 fault code indicates the oven too hot for setting, duh.
The F7 indicates a 'stuck' button in the control keypad. If it only occurs after a while and not as soon as turn on, it might just be being affected by the overheat problem.
BTW The part vendor I linked to gives a $60 refund if you return the defective part to the company. (It's still very expensive.)
