Jenn-Air Refrigerator JFI2089AEB2 - Water / Ice dispenser lever very hard to push
Maybe. Take the old one out and clean it. The lever just rotates on a couple pins and a spring pushes it back in place. There's also a interlock switch that can move out of place or wear out so you have to push harder to activate the switch. That's the correct part in your link.
jmucciol
NJ
I'll give a that a try. I've been unable to find a video or instructions that explain how to remove the dispenser. Do you have any instructions which you can share?
Remove the drip tray on the bottom of the dispenser. Then remove the two screws the drip tray was hiding that secures the frame. Push up on the frame and remove it. You can get it from there. (I think)
