mhsu_2000
- JFC2087HRS
- Jenn-Air
- More than 10 years
post ten year ago
www.applianceblog.com
got warm refrigerator section and ice buildup on back at the freezer on my Jenn Air Refrigerator Model/Serial JFC2087HRS/10208490EX , replaced the control board Dec 2020.
using the part was ordered from Amazon
amazon.com/gp/product/B07CWG3T5Y
found refrigerator section not cold anymore since last week. and ice buildup on back at the freezer, but not too much yet.
let freezer and refrigerator door open for a day, all ice melt/drained,
then run service test at room temperature
Service Test 1: Defrost Thermostat & Defrost Circuit Test
freezer indicator= 1; Refrigerator indicator either blank or "O", at toggling Refrigerator Up button, i.e, the defrost thermostat Open
Service Test 2: Compressor/Condenser Fan Test
freezer indicator= 2; Refrigerator indicator either "O" or "F", at toggling Refrigerator
Up button, but no effect on Compressor/Condenser Fan, no sure about compressor
but the fan is keeping running at the toggle between "O"/"F".
Service Test 3: Evaporator/Freezer Fan Test
freezer indicator= 3; Refrigerator indicator either "O" or "F", at toggling Refrigerator
Up button, and I can hear the fan is on and off accordingly, i.e. the test passed
Service Test 4:Fresh Food thermistor Test
freezer indicator= 4; Refrigerator indicator either "blank" or "P", at toggling Refrigerator Up button,
Service Test 5:Freezer thermistor Test
freezer indicator= 5; Refrigerator indicator either "blank" or "P", at toggling Refrigerator Up button,
Service Test 6:Open Damper Test
freezer indicator= 6; Refrigerator indicator either "O" or "C", at toggling Refrigerator Up button, I can hear the noise sound at the toggling.
after set Damper open, go back to Service Test 3: Evaporator/Freezer Fan Test, air blows into refrigerator section.
afterwards, closed all the doors and let it run overnight w/ default setting 4 for both freezer and refrigerator
then run service test at cold temperature
freezer indicator= 1; Refrigerator indicator either blank or "S", at toggling Refrigerator Up button, i.e, the defrost thermostat shorted (closed)
look like all hard-ware test ok, Should I go ahead to change the control board ?
Ming
Cotrol board replacement for Jenn Air Refrigerator Model/Serial JFC2087HRS/10208490EX
hi, My Jenn Air Refrigerator Model/Serial JFC2087HRS/10208490EX was down due to dead control panel two years back. Service person came and replaced the board. But recently ice dam build at the back of freezer, and also the temperature setting on the freeze stops working, either set to "-"...
Ming
