I have a 1992 Jenn Air wall oven model W131W, serial number 13878402KM.
I am having the following problems: F1 with beeping, usually following a baking period. Oven is not reaching the desired bake temperature even after manually adjusting the temperature the maximum 35 degrees.
I have tested the oven (temperature) sensor and it is about 1110 ohms at room temperature.
From what I have seen, this problem is variously identified as the touch pad, the oven sensor or the ERC (clock).
Any suggestions as what to try or test to narrow the problem to a specific, hopefully single, part?
AFH
AFH
