Jennair microwave keeps blowing fuses
zwasdl
Georga
Hi friends,
I have an over-the-range JennAir microwave, model # JMV8196AAS. The internal fuse blown last week, when I was cooking pumpkin for 15 mins. I replaced with a microwave ceremic fuse (250V 20A), and the range hood and lights worked, but the fuse blown again immediately when I tried to use microwave. Replaced with a different brand fuse, blown again in 1 second.
Thank you so much for any help and suggestion!
Wei
TechnicianBrian
Portland, OR
Hello Wei,
The fuse is blowing because one of your door interlock switches is no closing properly. The way to check is to disconnect the unit from the outlet, remove the grill and control panel, then do a resistance check of each switch. Two of the switches should read infinity until actuated while the third is normally closed and should read continuity until actuated. All three switches must be working and close in sequence or the fuse blows. There is a switch pack
containing two universal switches to replace the failed switch. Just make sure the wires are reattached to the appropriate terminals from the ones you take off.
