JES9800AAB Jenn Air broiler element stays on when baking
BruceS
Nashville
JES9800AAB
Jenn-Air
When baking, the broiler element (which I believe comes on for preheating), never goes off. When I turn the oven off, the broiler then turns off, but comes back on when the oven is turned back on. I have read mention of a relay board, but not sure if this model has one as I can't find that part. No error codes are displayed on the control pad.
BruceS
Nashville
Thanks Jake. My serial number starts with 23, but when I go to the link you indicated for serial #'s greater than 20, the compatibility tool says that part doesn't fit my model. Should I order it anyway?
Bruce
Jelly007
GA
Hi Jake,
I am having the same problem with a jenn Air double oven but can't read the data tag, if I remove my clock board can I get numbers from the board?
Possibly yes.:)
