JFC2290REM00 JennAir Refrigerator - Mullion Hits Right Door (Sometimes)
Haselmaier
Colorado
JFC2290REM00
Jenn-Air
I have a 3 year old Jenn-Air French Door Refrig/Freezer. Model # JFC2290REM00.
When it was first installed there were issues with the mullion not engaging at the top of the frame when the left door was closed. There were two service calls performed while in warranty.
After the second service call (which was quite a while ago) sometimes the mullion doesn't rotate the full 90 degrees upon opening the left door. When this occurs, closing the left door when the right door is already closed results in a loud BANG because the mullion strikes the right door. I've learned to close the left door slowly and look at the mullion to see if it's going to hit. But I'm getting sick of it.
Before I call someone - I thought I'd check here and see if people know of an easy fix.
Jim
Hi Jim,
Did either of those techs replace that mullion assembly? Did they replace any parts?
#10 is your mullion
#11 is your door closer bushing, check both of those to see if they are cracked or broken.
