JFC2290VEM5 REFRIGERATOR TOO COLD FREEZING
leosar
canada
JFC2290VEM5
Jenn-Air
hi,
french door fridge is set :0---37
freezer ok
food freezes in refrigerator.
checked the ff thermistor ok
rise setting to39 still freezing,PLEASE ADVISE WHAT TO DO.
need thermistor number to replace it
please help
thanks
How did you check your fresh food thermistor?
Usually it's a bad fresh food thermistor if the fresh food side is freezing.
You can ohm test it, unplug your refrigerator first.
The thermistor should measure about 8750 ohms at 32*F. You can put it in a glass of ice water for least 5 minutes before ohm testing it.
The thermistor only comes with the wire harness on your model:
WPW10119821 Harns-Wire
leosar
canada
THANKS FOR THE REPLY.
I CHECKED AGAIN THE THERMISTOR AS YOU SAY: OK.
WHAT ELSE COULD BE THE REASON?
THANKS
leosar
canada
HI,
SORRY FOR THE DUPLICATE ANSWER.
I HAVE THE WHIRLPOOL THERMISTOR 12003355.BUT IT IS NOT THE SAME READING.
NOW IF ADJUST THE TEMPERATURE IN TEST 211:
Service Test - 211 Fresh Food Temperature Adjustment
Press the Refrigerator Up Keypad or Down Keypad to change calibration of Fresh Food Temperature plus or minus in 1°F increments up to 6°F.
NOTE: Temperature will read in Fahrenheit regardless of what current temperature scale is being used.
DO YOU THINK IF I RAISE ONE OR TWO DEGREES,IT WILL SOLVE MY PROBLEME?
THANKS AGAIN
DO YOU THINK IF I RAISE ONE OR TWO DEGREES,IT WILL SOLVE MY PROBLEM?
Possibly, try it.
Please don't use ALL CAPS, that's considered yelling online.:)
