JFC2290VEM7 Jenn-Air 22cu ft 36" French door bottom freezer Service Manual
guho
NY
JFC2290VEM7
Jenn-Air
I am looking for a repair manual/service manual/Job Aid/Tech Sheet for my Jenn-Air JFC2290VEM7 refrigerator.
It is a Jenn-Air 22 cubic feet 36" wide French door fridge with bottom freezer, circa 2012.
I'd like to find out what the equivalent Whirlpool/KitchenAid models are, is as it could be that the service manual does not exist for all branded versions of the same refrigerator.
Many thanks for any help.
All I could locate is the tech. data sheet.
What is wrong with the refrigerator?
  • techsheet-w10475388-reva.pdf
guho
NY
Probably nothing but I want to be prepared. Thank you for providing the tech sheet. The issue i am having is that top shelf food has ice crystals. It is where the freezer air comes in via the damper. But it's probably user error as the fridge is so fully loaded that the cold air doesn't spread.
Glad to help.
Also check for air leaks in the refrigerator door gasket, that causes the warm kitchen air to settle there and condensate and ice crystals can then form as well.
