JGB700EEJ2ES GE Range burners wont light
fyxxer
Kansas City
JGB700EEJ2ES
A friends GE range burners won't light. Left rear and front right. Turn the switches and it clicks. I can see the spark on the others. I remove the burner top and base and cleaned them thoroughly and underneath with light steel wool to remove grease and corrosion.(usually that does it.) The right front if I held a little screwdriver by the electrode would give a weak spark. The rear I couldn't tell. Could the module be putting out a weak spark on just two leads or would it be the wires/electrode?
