JGBS22BEA2CT GE Gas Range Randomly Comes On
Dgriffith22712
VA
JGBS22BEA2CT
I have a 2002 GE gas range that has recently begun coming on randomly. I am aware that it is the thermostat. In the meantime will unplugging the range from the electric outlet prevent it from coming on? It does not operate from a pilot light. Thanks!
JGBS22BEA2CT
Yes it will.
Yes, it will likely need that, for sure check the wiring to make sure none has been cut and shorted to the metal framing...
Temperature-Control-Thermostat-WB20K8-00931652.jpg Oven thermostat assembly
Dgriffith22712
VA
Thanks for your reply. One more question, is there any risk of a gas leak if I don't turn the gas off as well?
