JGSP28SEK5SS oven won't light and one burner knob won't turn
SpecialK
AR
JGSP28SEK5SS
We have a new to us GE range model JGSP28SEK5SS and have a couple of problems.
First, and most important, is that the oven will not light. The broiler works fine. This leads me to believe that the oven igniter is at fault here, but I'd love a second opinion.
Second, and less important, is that one of the burner knobs cannot be pressed down, and therefore cannot be turned. This one I'm not sure what might need replaced, but would welcome any input on the solution.
It could be the igniter. There's several ways to check it. Disconnect the igniter connector and check it for continuity. Check for 120 VAC at the igniter when set to bake.
WB13T10045 Oven Igniter Assembly
Check the current draw with an amp meter.
SpecialK said:
....knobs cannot be pressed down,
That's usually caused when the knob stem is cracked or the metal spacer inside the knob stem is missing. Check if it will push down with the knob off. Try a different knob.
43646
SpecialK
AR
Thanks. Tested igniter and it has no continuity and the connector in the oven has 120v on bake so it must be the igniter.
On the knob, I forgot to mention I've already taken it off and tried to push it down with no knob on it. Still no go. Afraid to beat on it with a hammer to knock it loose....
SpecialK
AR
The valve that we cannot get to push down or turn is for the right front burner. Which part do we need to buy to replace that?
Thanks for all your help.
Here's the front:
The surface valve comes apart. It could just need some valve cock grease but most likely something broke inside the valve.
SpecialK
AR
@rickgburton Do you have affiliate links to another appliance site by chance? Appliance Parts Pros will not ship to Puerto Rico. I'd like to get you your affiliate income for your help, but if they won't ship to me I've got to go somewhere else.
SpecialK
AR
Or at the very least another trusted retailer where I can be sure I'm getting genuine parts?
SpecialK
AR
Much appreciated, let me know. I'd hate to risk buying a crappy part from somewhere else.
I don't really understand why they won't ship to PR. They ship to Hawaii and shipping to PR is very similarly priced on UPS and Fedex, and identical on USPS...I called them but they wouldn't budge.
Try RepairClinic and see if they ship to PR, if not then that's all we have.
SpecialK
AR
Thanks Jake! If that doesn't work I'll just ship to someone in the states and have them relay it to me.
Ok, sounds good.
SpecialK
AR
I just got the valve in today. I plan on replacing it tomorrow. Do you know how the panel is removed to access the valve?
Should be a couple of screws on the bottom of the console and one in each side.
SpecialK
AR
I'll look again but I glanced at it tonight and it looked like rivets in the side like maybe it pivoted on them. I took out a few screws from the bottom but it didn't budge. I'll look closer tomorrow, thanks
Unfortunately I don't have a disassembly manual but the parts diagram shows a screw:
43952
