ALANE2020
- JMC8100ADB
- Jenn-Air
- More than 10 years
Fuse blows and replacement blows as well.
You need to test the door switches for continuity by opening and closing the door. The monitor interlock is a "deadman" switch that shorts L1 and N together when the door is open. When does the fuse blow? Is it as soon as you plug it in or when you try to use it?Tested all 3 switches and they all are working. Now what?
Hi Rick-You need to test the door switches for continuity by opening and closing the door. The monitor interlock is a "deadman" switch that shorts L1 and N together when the door is open. When does the fuse blow? Is it as soon as you plug it in or when you try to use it?
I removed the plastic switch holder for the 3 and checked the 3 switches with a meter.
Don't remove the switches or the switch holder. Remove the wires on the switches. Connect your meter to the switch and open the door. The switch state should change.You need to test the door switches for continuity by opening and closing the door.
Remove the two wires on the primary side of the transformer and tape the ends. Start the microwave and see if it still blows the fuse. If the microwave continues to work the short is the high voltage side of the machine.it makes a quick buzz and goes dead and blows fuse.
Thanks! I put the switches back in and they all test ok with door open/close. Do I take 2 wires off the capacitor side of transformer or side sword control panel?Don't remove the switches or the switch holder. Remove the wires on the switches. Connect your meter to the switch and open the door. The switch state should change.
The problem is on the low side of the transformer, door switch, control board, etc; etc.Then what if it blows fuse after testing?
