FIXED JMV9169BAP Blowing fuse when I press start
Brennanrp
Missouri
JMV9169BAP
Jenn-Air
I just pressed start and found that my fuse is blown with of course no power. Can I just replace the fuse and be OK? What is causing the fuse to blow? Thanks!
Brennanrp
Missouri
Jeff! Thanks much. I replaced the fuse and it appears to be working. I am worried it will blow again????
It may....just pay attention to how....opening the door, closing the door, pressing start, etc ,etc.
