JNM7196DF1BB Clock Not Continuous Display and Microwave came on when I shut the door
brmommy
Ohio
JNM7196DF1BB
A couple things I noticed this morning. The clock on my microwave is disappearing randomly. Then one time when I shut the door this morning, the microwave came on on it's own. I tried to push the stop button to turn it off, but that didn't work. I had to open the door to get it to stop. It appears to heat food fine once it is on. Sitting here pondering on this, I remembered a day or two ago sitting in the kitchen and hearing some kind of pop sound near the microwave and cooktop stove. I didn't know what it was and everything seemed fine until this morning. No problems with the interior light not coming on. I took the control panel off without disconnecting the wire just to glance at it. I didn't see any obvious problems. I did NOT disconnect the wires so can not see the other side of the board. So I can heat food, but something obviously isn't right. I'm wondering about the control board. Thoughts?
Rick is very good with microwaves, I will see if he can assist you.
brmommy
Ohio
Thank you! I would greatly appreciate that. It's such a pain to install a new one of these, I'd much prefer to repair it. :)
brmommy
Ohio
I meant to say it is a pain to install a new Microwave. I'd much rather repair it.
