JS42PPDUDB15 Jenn Air. Frost at top of freezer near ice maker
Happypancake
Pa
JS42PPDUDB15
Jenn-Air
Hello
I’ve recently been seeing frost build up as shown in picture. Freezer seal seems fine. I just turned off the water to the ice maker as I have seen small water drops on the inside surface.
Any help would be appreciated
HP
Corrected model number
Happypancake
Pa
So turning off the water to the ice maker seemed to stop ice from forming. Leak/plug somewhere?
Another note, I did have my freezer set at -3F and sometimes it reached -10F.
Thoughts ?
Hi Happy,
This model number does not pull up anywhere whatsoever, even if you google that model number nothing pulls up. Where did you buy this refrigerator at?
Without a model number we can pull up, we are dead in the water.
I'll ask our other tech bigbuck about if he can find anything on this model number.
Why the hell couldn't Rick and I find that model number??????????
Thanks Guys!
Wait, I see now.
Happy look at your 1st post: Model Number: JD42PPDUDB15, then look at the model number in the Topic JS42PPDUDB15
Rick and I were looking for JD42PPDUDB15. Having the model numbers match is very important my friend. LOL
Happypancake
Pa
so water to ice maker has been off for a few days and frost is gone. ill either turnthe water back on and see what happens or pull the ice maker. Is there some type of drain that might be plugged causing the issue?
Turn the ice maker back on and see what happens, your freezer is WAY to cold even at -3. Normal for all freezers is 0 to 10 degrees.
Ok, sounds good, if it does the same thing at 0 to 10 degrees, then feel the bottom of the ice maker and see if its warm.
Did you feel for heat underneath the ice maker?
