Just need to connect some parts
LostUser
Michigan
So I took apart my Kenmore microwave, I need help where to re-connect the wires to the capacitor.
I am including a picture.
I have a white/red wire coming from the Magnetron and a red/black connector coming from the high voltage transformer.
I don't know which side of the capacitor the wires go to.
The sheet inside the microwave showed various model #'s: 66223 / 66229 / 66222 / 66227 / 69113
Thanks for any help
LostUser
Michigan
Thanks for your help. I connected them as you showed and it is working fine. Looks like the problem may really be the turntable support --- there is a crack on both sides of the sleeve. It is probably expanding when the turn table motor's nylon insert spins.
Thanks again.
LostUser
Michigan
What was the original problem?
On retrospect, I should have looked for a support forum first. Pardon my descriptions as I don't know the proper names of some of these parts.
The original problem is that the platter only turns intermittently. The plastic bushing part of the turntable is cracked on both sides. This is the part of the turntable that slides down over the insert from the motor.
Possibly the motor nub that connects to the turn table (half circle piece/insert) is turning but the crack in the turntable bushing lets the nub slip inside the bushing. Heavier items don't turn whereas some lighter items do.
I have tried fixing the cracked portion but I think the leverage/force applied is too much for a simple glue repair and I don't want to wrap that bushing with anything considering the microwave is heating things up.
I am going to order the rotating ring assembly---after searching for it online, it is a pretty cheap fix if that is the problem. It has three arms.
I just need to find the right size. The arms measure about 4 3/4 inches from center and the bushing is about 3/8 inches long. I don't see any leeway on a longer length arm because the glass tray has a raised ridge underneath, just at the edge of the rotating rings arms.
What are your thoughts?
LostUser
Michigan
Thanks for all your help.
I ended up ordering the part. Although usually I would rather do a repair if it makes sense and will last---depending on the circumstances.
For the JB weld, if I was going to try repairing it again, your advice is sound. After that had cured, I would probably also surround the connector with the epoxy as well just to give it some outer strength as the crack is on both sides. I just wasn't sure of what was safe (or not) to use as a repair in a microwave.
