FIXED JVM1630WFC01 GE Replaced Breaker Fuse/Thermal Fuse - Can't turn fan OFF
iLoveLobster
Toronto, Canada
JVM1630WFC01
I had some issues with my microwave turning on and checked to see what was blown out by following this YT video.
What I've done:
- Checking every component in that video for continuity deemed the fuse/thermal switch blown out.
- All interlock/door switches seem fine as I got a signal for continuity.
- As the topic says, I replaced these, was able to power on but can't seem to turn the fan off while in the OFF position.
- Once microwave is powered on the fan is automatically on (I think the speed is equivalent to the LOW setting).
- I can cycle through the fan modes but OFF doesnt turn off.
Parts I replaced with:
Breaker(?) Fuse: partselect.ca/Models/JVM1630WFC01/
Thermo Switch: WB27X1127
That is a thermal fuse. If this was installed for the fan thermostat ( which is open and closes if the bottom of the microwave gets too hot ) the fan will stay on.
Your model is Canadian so most parts and breakdowns are not online.
iLoveLobster
Toronto, Canada
Sorry I'm a bit dense here @jeff1 . Does that mean I ordered an incorrect part?
Sounds like it. If your new part is closed ( has continuity ), then yes it is incorrect.
The fan thermostat should be open ( no continuity ).
iLoveLobster
Toronto, Canada
Thanks @jeff1 - looks like thats exactly what I did and the original0 part that deemed faulty actually was working.
Before I close this, the only other issue I am having is a rattling when the microwave is on. When the fans are on, I hear no rattle.
  • video_2020-06-12_09-14-30.mp4
