JVM1705SP2SS Microwave - Need Schematic / Service Manual
LarryR49
Oregon
JVM1705SP2SS
Our GE microwave hood just quit putting out microwaves. Timer starts, but no fan/turntable/zap. First indication of problems was the fan would start when the door was opened (no buttons pressed). Since I'm a electronics/radio guy, I'd like to fix it myself, but need a schematic and service manual. Can't seem to find one on-line. Thanks!
Recheck model number
JVM17508P289
That model number doesn't look correct. I suggest you double check it.
Check the functioning of the door switches.
need a schematic
There's a schematic inside the microwave somewhere.
and service manual
I don't know where you'll find a service manual for it, sorry.
Took unit apart and the Schematic & Wiring diagram were behind the control panel. Checked the door switches and the Monitor Interlock Switch (#26) would not work, so have ordered a replacement: WB24X830. Ordered a set of the other micro-switches and will replace them, too, as a precaution: WB24X829. That should fix it!
