JVM1740SP2SS - Recirculates and top exhaust?
qqcarmen
Seattle
JVM1740SP2SS
Hi all,
I have a GE Microwave installed above our range. Our cabinets are always greasy, we wipe and clean them every other weak but it seems like they are always covered in a film of grease. I dismantled as much of the microwave as I could and washed out the greasy parts (there were a lot!) and thought a deep cleaning would fix the issue. Two weeks later and there is grease everywhere, dripping from the bottom and inside the microwave.
I checked to see if our duct is working. When the exhaust fan is on, I can go outside and see the outdoor covers flapping so I believe it is circulating the air outside, however above the microwave there is the recirculating fan, and when I put my hand on it, I can feel air blowing at me too. I wonder if it is wrongly configured and also recirculating the air? Does anyone know if this if possible before I take it apart and investigate?
Side note: Would it be hard to install a stronger range hood (not microwave) given my current setup?
