JVM2070 Control Panel/Touchpad not working
fatone
NY
JVM2070
My GE microwave control panel/touchpad isn't working. The lights and fan work fine. It seems to be an intermittent problem such as moisture/steam from cooking knocking the unit out. I have seen on this forum and other forums, people complaining about the same thing. I also have read that it is a bad design with the Magnetron too close to the circuit board of control panel.
Currently, I opened it up and checked all the connections and even did the cleaning of the connections with a pencil eraser. Didn't fix it! Previously, I sent it out to a repair guy and he did fix it but he told me it would most probably happen again due to the moisture/steam issue since it is above an oven range. So, it was fixable without buying the expensive control panel from GE. I would hope someone knows how to fix it so I don't have to keep paying someone to fix it because it seems that they could just be cleaning the circuit board and/or control panel.
Any ideas?
