JVM3670SK06 GE Microwave stops heating, interior fan turns on when door opened
su_A_ve
NJ
JVM3670SK06
Microwave JVM3670SK06 all of a sudden stopped heating. Also noticed that when you open the door, the interior fan (cooling?) starts as well as the interior light. Close the door, and the light and fan turns off.
After several hours, it started working again, until the following day when it experienced the same issue.
Any ideas as to where to start troubleshooting this? It's a family member, and the problem not heating just started. But not sure the fan going on when the door is opened is something new or even if it was by design.
Close to 10 years old so may bite the bullet and get a new one...
TIA.
Microwave all of a sudden stopped heating
How?
Stopped running but the clock was counting down?
Should check the door switches, door switches wires, door switch mechanism and door key.
*Some* door switch info:
https://www.applianceaid.com/microwave-door-switch-help.php
https://www.applianceaid.com/component-testing.php
https://www.applianceaid.com/microwave-door-latch-replacement.php
jeff sr.
