JVM6175EK1ES Blows thermal fuses
barryww
grangerr, in
JVM6175EK1ES
Less than 1 year
Unit has blown two thermal fuses in two months. Otherwise runs okay. Exhaust fan not running either time, Magnatron cooling fan running properly. Both times blew approx. 2-4 minutes into cooking cycle and range below unit was cooking other food. Unit over temp thermostat has tuned exhaust fan on automatically before but not in either instance of fuse blowing. Magnatron is obviously getting to hot, but what to check or do now?
Is this microwave under a year old?
If its getting to hot usually the bad part is the MAG.
Look at end of the antenna on the mag tube and see if it is burned or pitted. Here's the part you need:
WB27X11079 Magnetron Asm
