FIXED KBFS20EVMS13 Loud noise from top of fridge
woodpile
Los Angeles
KBFS20EVMS13
Hearing a loud noise from the inside of our Kitchenaid fridge. Seems to come from the top rear area.
Anyone recognize the issue? Repair tips would be much appreciated!
It sounds like your air damper motor is broken/stripped and making that noise.
Here's the air damper assembly for your model you can order:
WPW10594329 Control
Remove the cover, remove the 2 screws, pop out the plastic/foam parts, disassemble the electrical connection to the control unit, replace air damper assembly and reassemble.
To remove the cover: You just grab the grill part and pull it off. There will then be 2 screws under it that allow you to take the outer shell off. Then that damper just pulls out and remove the electrical connector to it, then install the new one.
woodpile
Los Angeles
That fixed the issue!
Thank you so much Jake, I owe you one. I really appreciate your taking the time to help.
Cheers!
Excellent, glad to hear that.:)
