KBSN608EPA00 kitchen aid refrigerator and freezer lights flickering. How do you repair
Dino55
Olympia
KBSN608EPA00
Refrigerator and freezer lights are flickering. How do you repair/fix?
Ok, you have 5 LED lights in the refrigerator section and 4 LED lights in the freezer.
Look for any of the LED lights in the refrigerator and freezer that is NOT flicking and COMPLETELY OUT, and that will be the bad one you will need to replace and then the others will work fine after you replace it.
Here's the LED light for your model: W11462342
Both the freezer and refrigerator sections use this exact same LED lights.
Dino55
Olympia
Hi, the top left light in the refrigerator is the only light flashing. All others are on. Every light in the freezers is flashing, 4 total in freezer
Ok, the tech data sheet says this: Troubleshoot the LEDs that are not turning on. Each LED has to be replaced one by one. Once the failed LED is replaced, all the other LEDs will turn on as well.
That's all it says to do.
So I'd do that next with a known good one.
