KCMS1555SSS2 Kitchenaid Microwave bottom door switch wire burnt
Vail67
Chicago
KCMS1555SSS2
Hi all,
My Kitchenaid Microwave (KCMS1555SSS2) went out after I steamed something--lights still on, countdown timer works, but no sound/heat/turntable movement when I try to microwave something. From research it looked like one of my lower door switches had an issue. I opened the microwave and indeed, that switch appears a little burnt along with one of the connecting wires. I already bought the replacement switch but I am wondering what to do about the wire? I am not even sure what the plastic tab connector is called. If anyone could walk me through what I am supposed to do I would really appreciate it! Here's a pic of the issue and then one pic showing the bad wire with one of the wires that doesn't have an issue.
Thank you so much!!
The plastic terminal cover isn't absolutely necessary. It is just an insulator to try to prevent contact with other metal surfaces.
Cut the connector off the wire and install a regular female spade terminal in place of it.
BTW. Installing a connector like that back onto a new switch would usually damage the new switch in a short time. When a connector gets heated like that, both terminal and the component it was attached onto should both be replaced together.
Vail67
Chicago
Thank you!! You think this would work? https://www.homedepot.com/p/Tyco-El...ct-Fully-Insulated-Nylon-EB0280-000/202204295
Those look like they'd be fine. Make sure they're attached securely onto a non-affected portion of wire.
