bobo9912
- KDFE104DSS2
- KitchenAid
- 1-5 years
So I am hoping someone can point me in the direction of what component on the circuit board might be causing this problem. Initial complaint was dishwasher not cleaning properly and code stored was 7-1. I checked heater element and it worked well directly to 120v. I found fried wires going to circuit board and repaired them and resoldered connections on circuit board. But I feel like a relay or component must be bad causing the voltage to drop under load to a such low amount that it won't turn a light on or obviously heat up the heating element. Youtube video I made
This is before I resolderd the connection on the circuit board and cut back the wires to good wire and soldered on new connection and plugged them in the right spots. Everything works and dishwasher will cycle but heating element obviously isn't getting the voltage it needs when under load if it won't power a lamp. Looking for which pieces on circuit board I should replace to have best chance of not spending 200 on new board. Thanks!
showing it. And the damage I found to the wires.
S
