FIXED KDPE334GPS0 Detergent Dispenser Not Opening
gijoecam
KDPE334GPS0
Hi, everyone!
I have a 4 year old Kitchen Aid KDPE334GPS0 whose detergent door seems to have quit working. How can I check and see if it's the board or the wax motor on the dispenser? When I pulled my kick plate off, the envelope where the service manual should be was empty. I installed it myself, but have zero recollection of removing the service manual, so I'm not sure where the heck it disappeared to?
After a bit of reading here, I was able to get the dishwasher into test mode, but I have no instructions on what to do from there to test it? Any guidance would be greatly appreciated!!
Edited to add: well, I think I found the issue, but unfortunately, I'm not sure how to fix it!
I found the service manual in the sink. Apparently when I went to brush the dust bunnies off the insulation, the manual fell out of the folder and into the sink!
I removed the front panel and found that one of the purple wires that feeds the dispenser broke off right at the connector. (Photos attached). How the heck do I fix this now? I don't see an easy way to correct this... Perhaps a new connector is in order? I'm guessing this little thing probably can't be easily disassembled to replace the wire?
While I had it open, I checked the resistance, and the dispenser read 290 ohms, which is perfect. (Manual says 260-300).
Thanks again!
Looks like new wire harness time as those type of connectors are normally not available to us as a seperate part.
LINK> Wire harness
jeff sr.
gijoecam
Thanks. I figured as much
I found a local repair guy who happened to have an old harness that appears to have the connections I. We'd. The wires are blue instead of violet, but I think it should work. Will be trying it this evening. Fingers are crossed!
gijoecam
As Red Green says, if they don't find ya handsome, they should at least find ya handy!
Success!
Ran a quick wash and success!!
