KDRS483VSS03 KitchenAid Dual Fuel Range Oven Not Heating Properly
dman535
Nashville, TN
KDRS483VSS03
When trying to bake with this oven the control panel will report a temperature, but the oven does not maintain it and the panel does not update the loss in temperature. Here is the scenario played out.
1. Heat oven to 450 convect bake.
2. After unit reaches temp - turn oven off
3. Set temp to same heat point within seconds of turning off and the temperature will show 50+ degrees less.
4. Sometimes oven temp will freeze at preheating stage while the oven temperature does not decrease, turning oven off and then on again shows updated temperature lower.
I replaced the temperature sensor as the original was out of spec when checked with an ohm meter. I have not pulled out the replacement to see if it is still within spec. I am concerenced that its the main board as its not reporting back the correct temperature as the oven is supposedly trying to heat.
All other functions see normal with no error codes.
Added complete model number
Your missing some digits after the last "S". We need those last two digits please.
It should be one of these below:
KDRS483VSS00
KDRS483VSS02
KDRS483VSS03
KDRS483VSS04
I did locate a service bulletin, what is the serial number of this range?
Code Dates: D400 through D540
Possible Concern(s):
Oven Lights may not shut off when door is closed, temperature complaints or oven shuts down.
Thanks! I'm attaching that service bulletin below, even though your serial number is out of range at D633
That service bulletin is for Code Dates: D400 through D540
But you can read it and try what it suggests first.
  • servicepointer-w10780875-revd.pdf
dman535
Nashville, TN
Thanks for posting. I wil dig into a bit. I cycled the door two dozen times this morning and the switch seemed to be operating properly. Does this unit have any type of built in diagnostics?
Yes, I'm attaching your tech. data sheet below.
On Page 2 Do--->To Enter Diagnostics Mode
Let us know what fault code, if any, you get.
  • W10403297-reva.pdf
dman535
Nashville, TN
That is great info, thanks for sharing.
The only error code was for the temp sensor when I swapped it out.
I contacted Kitchen_aid today and it looks like I still have about 6 months of warranty on the control board and the heating elements. They are sending out a tech to look at it, and hopefully resolve it. Will report back what I find.
Ok great!
Yes, let us know what they find.
