KDTE204EWH Leaves water in bottom when finished but pumps when cancel drain is pressed
bigbuilder
ontario
KDTE204EWH
Hello,
Thankyou for letting me join your forum.
I have a kitchenaid KDTE204EWH that was purchased in July of 2017. Has worked fine until now.
It leaves water in the bottom when its finished.
But will pump out if I hit the cancel/drain button.
I have cleaned the filters.
I have turned the power off to the unit and tried it after that.
Does anyone have a pointers here.
The only thing different is that it is in a cottage and is drained in the fall. It started this in the spring when the water was turned on. If that is relevant.
Thank you
bigbuilder
ontario
Hi Again,
Online i read about re-setting the computer board?
Has anyone ever done that? I dont know how to do it but at this point I will try anything.
Any help is appreciated.
We need the complete model number first. The model number tag is located inside the door on the tub frame.
It should be one of these below:
KDTE204EWH0
KDTE204EWH1
KDTE204EWH2
KDTE204EWH3
KDTE204EWH4
Where does this dishwasher drain line hook up to? Underneath the sink directly to your sink plumbing? To a air gap first then to the plumbing? To the garbage disposal?
bigbuilder
ontario
Hi Jake, I wont be with the machine again until tomorrow morning.
But this is from the receipt.
Kitchenaid 24" Fully Integrated Dishwasher
Mod# KDTE204EWH- White
Ser# F71801168
It connects directly to the kitchen drain above the trap. No air gap. No garbage disposal. Trap is clean.
It worked fine for over a year with this install.
bigbuilder
ontario
Correction.
Mod# KDTE204EWH
Ser# F71202934
Sorry the earlier one was one that came but was dented and they replaced with this one.
I forgot about that.
I still need that last digit.:) When you get back to your dishwasher, please post it.:)
I'm also going to need you to stay with the dishwasher for the whole cycle and when it does its first drain see if all the water is gone from the tub, just open the door after the first drain.
How will I know when it does its first drain?
You will hear the wash motor stop, and then the drain motor will start and you should hear it draining into your sink plumbing.:)
