FIXED KDTE234GPS0 KitchenAid Dishwasher not drying dishes
Jim79lynn
Colorado
KDTE234GPS0
My dishwasher is 3 1/2 years old, and the circulation motor went out. I replaced it successfully. However, since then, the dishes are not drying. I do not know if the heater is heating the water while washing. I measured the resistance of the heating element, and it is ok. I wonder what I could have done during the circulation motor replacement to cause this.
Hi Jim,
Make sure both heating element wires are connected tight to your heating element terminals.
Also make sure the wires going to your high-limit thermostat are connected tight too.
#26 is your high-limit thermostat
#27 is your heating element
Jim79lynn
Colorado
Thanks for the suggestion. Those connections look and feel good. I attached a couple of pictures.
Jim79lynn
Colorado
I also measured the resistance across the thermostat and verified that it is 0. The heating element measures about 30 Ohms, and the wiring from it to the thermostat checks out.
Ok, Now run the SERVICE DIAGNOSTICS CYCLE, and let it run all the way through to reset it back to default.
--->Invoking Service Diagnostics clears all status and last run information from memory and restores defaults. It also forces the next cycle to be a sensor calibration cycle.
Do that now, and report back.:)
Ok, good Jim.
Next time you do a load see if the heating element gets hot in the dry cycle.
Jim79lynn
Colorado
It did! That is surprising. Does that mean it will keep working? If so, thanks tons! I wonder what I did to cause the problem?
Yes Jim, that means it should continue to work.(y)
On some models after you replace a part or parts you need to run the diagnostics cycle to reset everything back to default, then the heating element starts working normally again.:)
Anytime!
