creativepart
- KDTE334DSS0
- KitchenAid
- 1-5 years
Started a Light wash cycle about midway through (timewise) the front panel LED that indicates cycle position went dark. Opening the door (only way to see control panel) the wash mode has changed to Normal, the heated dry is lit properly, the Start light is lit and the Washing light is lit. At that point none of the touch buttons work you cannot change, start, cancel anything. After waiting 24-hours with it still in this position I did a power off / on reset. After power off for 30-min when it's turned back on the Touch Panel is dark and not-responding to touch. No lights no sound anywhere.
Being relatively handy, I removed the door and bought a new control board ($214) and installed it. Nothing. Online troubleshooting suggested the control panel was dead. So, I put the original control board back in the DW and bought a new control panel ($262). When I plugged this in everything appeared to work normally. All the buttons worked and the lights lit properly.
So, I ran a Light Wash cycle to test everything... exact same result. Mid-cycle the outside LED went dark, the cycle stopped, the wash mode changed to Normal, heat, start and washing were lit. I waited another 24-hours and recycled the power. Now this NEW Control Panel is dark and not responsive at all. I did try reinstalling the new circuit board just for yuks and giggles and nothing happens.
Certainly there is some reason why cycling the power after a mid-cycle stall is causing the Control Panel to go dead. Any and all help is appreciated. I do not want to purchase another Control Panel and or Circuit Board.
By the way I tried all the tricks to enter a diagnostic mode - since the control panel is totally dead pushing buttons 1-2-3 1-2-3 or 1-2 five times does nothing.
