bongoherbert
- KDTM354DSS0
- KitchenAid
- 1-5 years
I've got a thing that just happened today - I see some similar but not exact problems here -
Basically- on any cycle, even just 'rinse', the cycle starts by running the drain pump. Then the machine fills. During that time, the main pump (I think) runs for a few seconds, for a few times. After this, the machine continues filling for a few seconds, then it stops and the front-panel flashes. Any attempt to continue the cycle fails. I have to drain it. There's no way it will keep running. I hear a relay 'click' as this happens, fwiw.
I ran the 1-2-3 diagnostics. There were several errors, 10-3, 9-1, 6-4, 8-2 I reset it and let it continue through the diagnostics.
Interestingly, it would go through the first test, show the 'clean' and 'sanitized' indicator (which, according to the service insert, means the temperature is OK maybe?) and then stop with the 'bar graph' on the front flashing 7 times and then nothing. All LEDs / front panel off. No more tests seem to be run.
Thoughts? Chaos?
Thoughts? Chaos?
